MIKROE-5153
MIKROE-5153
    MIKRO
    ICP-20100 压力 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-5153 数据手册
Pressure 20 Click PID: MIKROE-5153 Pressure 20 Click is a compact add-on board that contains a board-mount pressure sensor. This board features the ICP-20100, a high-accuracy digital barometric pressure and temperature sensor from TDK InvenSense. The ICP-20100 is based on MEMS capacitive technology with ultra-low noise, low power consumption, and temperature stability alongside programmable output: all-pressure, all-temperature, or pressure and temperature output. It converts output data into a 20-bit digital value and sends the information via a configurable host interface that supports SPI and I2C serial communications. It measures pressure from 30kPa up to 110kPa with an accuracy of ±20Pa over a wide operating temperature range. This Click board™ is suited for various pressure-based applications, industrial, consumer, weather stations, and more. Pressure 20 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Pressure Applications Can be used for various pressure-based applications, industrial, consumer, weather stations, and more On-board modules ICP-20100 - digital barometric pressure and temperature sensor from TDK InvenSense Key Features Low power consumption, advanced absolute and relative accuracy, improved temperature stability, programmable output and noise performance, digital filtering for pressure signals, programmable interrupt, selectable interface, and more Interface I2C,SPI ClickID No Compatibility mikroBUS™ Click board size S (28.6 x 25.4 mm) Input Voltage 3.3V Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads Pressure 20 click example on Libstock ICP-20100 datasheet Pressure 20 click schematic Pressure 20 click 2D and 3D files Powered by TCPDF (www.tcpdf.org)
MIKROE-5153 价格&库存
很抱歉,暂时无法提供与“MIKROE-5153”相匹配的价格&库存,您可以联系我们找货
