MIKROE-5300
MIKROE-5300
    MIKRO
    VCNL3036X01 近程 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-5300 数据手册
Proximity 18 Click PID: MIKROE-5300 Proximity 18 Click is a compact add-on board that provides a close-range proximity sensing solution. This board features the VCNL3036X01, a high-resolution digital proximity sensor from Vishay Semiconductors. Besides the proximity sensing element, the VCNL3036X01 also integrates a mux and a driver for three external LEDs, which are located near the chip on the board, photodiodes, amplifiers, and analog to digital conversion circuits into a single CMOS chip. Proximity 18 Click provides absolute distance measurement, whatever the target color and reflectance, and is accurate up to 50cm. This Click board™ is suitable for proximity/optical switch applications for consumer, computing, automotive, and industrial purposes. Proximity 18 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Proximity Applications Can be used for proximity/optical switch applications for consumer, computing, automotive, and industrial purposes On-board modules VCNL3036X01 - close-range digital proximity sensor from Vishay Semiconductors Key Features Fast and accurate distance ranging sensor, fully integrated module, low-power consumption, I2C interface, programmable interrupt, up to 500mm ranging, various basic proximity function settings, and more Interface I2C ClickID No Compatibility mikroBUS™ Click board size S (28.6 x 25.4 mm) Input Voltage 3.3V,5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads Proximity 18 click example on Libstock VSMD66694 datasheet VCNL3036X01 datasheet VLMTG1300 datasheet Proximity 18 click 2D and 3D files Proximity 18 click schematic Powered by TCPDF (www.tcpdf.org)
MIKROE-5300 价格&库存
很抱歉,暂时无法提供与“MIKROE-5300”相匹配的价格&库存,您可以联系我们找货
