MIKROE-5337
MIKROE-5337
    MIKRO
    APS6404L-3SQR DRAM 存储器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-5337 数据手册
DRAM Click PID: MIKROE-5337 DRAM Click is a compact add-on board representing a dynamic random-access memory solution. This board contains the APS6404L-3SKR from AP Memory, a high-performance 64Mb SPI/KPI PSRAM memory organized as 8M x 8 bits each. This Pseudo-SRAM device features a high speed, low pin count interface and incorporates a seamless self-managed refresh mechanism to maximize the performance of memory read operation. It has 4 SDR I/O pins and operates in SPI or QPI (quad peripheral interface) mode with frequencies up to 133 MHz. This Click board™ is most suitable for low-power and low-cost portable applications. DRAM Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type DRAM Applications Can be used for low-power and low-cost portable applications On-board modules APS6404L-3SQR - 64Mb PSRAM (Pseudo-SRAM) memory from AP Memory Key Features Low power consumption, SPI/QPI with SDR mode, high performance, organized as 8M x 8bits, page size of 1024 bytes, self-managed refresh mechanism, software reset, and more Interface QSPI,SPI ClickID No Compatibility mikroBUS™ Click board size S (28.6 x 25.4 mm) Input Voltage 3.3V Resources mikroBUS™ mikroSDK Click board™ Catalog Click Boards™ Downloads DRAM click example on Libstock DRAM click 2D and 3D files APS6404L-3SQR datasheet DRAM click schematic Powered by TCPDF (www.tcpdf.org)
MIKROE-5337 价格&库存
很抱歉,暂时无法提供与“MIKROE-5337”相匹配的价格&库存,您可以联系我们找货
MIKROE-5337
  • 1+96.516321+12.48807
库存:34
MIKROE-5337
  • 1+96.067561+12.43000
