EA KF050-40
EA KF050-40
    ELECTRONICASSEMBLYGMBH
    40 位置 FFC,FPC Cable 0.020"(0.50mm) 4.000"(101.60mm)
EA KF050-40 数据手册
Part Number : 151660427 Product Description : 0.50mm Pitch PremoFlex FFC Jumper, Same Side Contacts (Type A), 51.00mm Cable Length, Tin (Sn) Plating, 40 Circuits Series Number : 15166 Status : Active Product Category : Flexible Printed Circuit (FPC) Flex Jumpers Documents & Resources Drawings Drawing 151660427_sd.pdf Specifications Product Specification PS-15166-001-001.pdf Product Environment Compliance Compliance GADSL/IMDS Not Relevant China RoHS EU ELV Not Relevant Low-Halogen Status Not Low-Halogen per IEC 61249-221 REACH SVHC Not Contained per D(2023)3788-DC (14 Jun 2023) EU RoHS Compliant per EU 2015/863 Multiple Part Product Compliance Statements - Eu RoHS - REACH SVHC - Low-Halogen Multiple Part Industry Compliance Documents - IPC 1752A Class C - IPC 1752A Class D - Molex Product Compliance Declaration - IEC-62474 - chemSHERPA (xml) EU RoHS Certificate of Compliance Part Details General Status Active Category Flexible Printed Circuit (FPC) Flex Jumpers Series 15166 Description 0.50mm Pitch Premo-Flex FFC Jumper, Same Side Contacts (Type A), 51.00mm Cable Length, Tin (Sn) Plating, 40 Circuits Comments Contacts on the same side, Type A Product Family FFC Cable Jumpers, Premo-Flex Flat-Flexible Cable Jumpers Product Name Premo-Flex FFC Jumper UPC 884982849259 Current - Maximum per Contact 0.5A Voltage - Maximum 60V AC Cable Length 51.00mm Circuits (Loaded) 40 Contact Layout Type A (same side) Design Feature Ultra-Flexible Material - Plating Mating Tin Net Weight 1.000/g Packaging Type Bag Pitch - Mating Interface 0.50mm Temperature Range - Operating -40° to +105°C Wire/Cable Type Flat Flex Cable Wire Size (AWG) N/A Electrical Physical Mates With / Use With Mates with Part(s) Description Part Number Easy-On FFC/FPC Connector, 0.50mm Pitch, V-Flip Series, Vertical, 4.05mm Height, 40 Circuits, Copper Alloy, Tin-Bismuth Plating 5019514000 Easy-On FFC/FPC Connector, 0.50mm Pitch, Slider Series, Vertical, 3.90mm Height, 40 Circuits, Tin-Silver-Bismuth Plating 0525594033 Easy-On FFC/FPC Connector, 0.50mm Pitch, Slider Series, RightAngle, Top Contact, 2.00mm Height, 40 Circuits, Tin-SilverBismuth Plating 0541044033 Easy-On FFC/FPC Connector, 0.50mm Pitch, Slider Series, RightAngle, Bottom Contact, 2.00mm Height, 40 Circuits, Tin-SilverBismuth Plating 0541324033 0.50mm Pitch Easy-On FFC/FPC Connector, 1.90mm Height, Single Bottom Contact (FS19), Right-Angle, Surface Mount, ZIF, 40 Circuits 5052784033 This document was generated on Jan 24, 2024
EA KF050-40 价格&库存
很抱歉,暂时无法提供与“EA KF050-40”相匹配的价格&库存,您可以联系我们找货
