A28100-015
A28100-015
    OMNETICS
    SMD
    15 位 D 型,Nano-D 插头,公引脚 连接器
A28100-015 数据手册
PART NO. MATERIALS & SPECIFICATIONS .345 8.76 HOUSING: ALUMINUM 6061-T6, NICKEL PLATE PER AMS-C-26074 2X #0-80 UNF-2B CONTACT: BERYLLIUM COPPER PER ASTM B194, C17200, GOLD PLATED PER ASTM B488, (HARD GOLD) TYPE II CODE C, CLASS 1.27 ECO DATE G 96463 01-30-10 .105 2.67 8 .0575 1.46 A .140 3.56 APP TLM B .125 3.18 .040 1.02 A 9 TERMINATION: SOLDER COATED WITH SN63A PER J-STD-006 OR AMS-P-81728 REV .345 8.76 A 1 INSULATOR: LIQUID CRYSTAL POLYMER (LCP) PER ASTM D5138 A28100-015 15 .095 2.41 .0125 0.32 .235 5.97 CURRENT RATING: 1 AMP MAX PER MIL-DTL-32139 .220 5.59 SECTION A-A CONTACT RESISTANCE: 71 MILLIOHM MAX (71mV DROP MAX) @ 1.0 AMPS PER MILDTL-32139 .175 4.45 PERFORMANCE: PRODUCT FAMILY TESTED TO AND PASSED THE PERFORMANCE SPECIFICATIONS OF TABLE VIII OF MIL-DTL-32139 .085 2.16 .017 (TYP) 0.43 .450 11.43 .042 MIN 1.07 (TYP) .345 8.76 .031 0.79 1 2X #0-80 UNF-2B .018 0.46 .187 4.75 2X .050 1.27 1 .006 A (TYP) .245 6.22 MNPO SLDW DETAIL B SCALE 6 : 1 THIRD ANGLE -TOLERANCESUNLESS OTHERWISE NOTED DIMENSIONS IN INCHES 2 PL DEC 3 PL DEC 4 PL DEC ANGLES .01 .005 .0005 1 DFTM. AAS 05-05-04 TITLE: APP'D. DATE .345 8.76 SUGGESTED PAD LAYOUT ACTUAL SIZE DATE CHK'D. 9 .050 1.27 .150 3.81 .010 (TYP) 0.25 SOLDER COATED THIS DRAWING CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION WHICH IS THE PROPERTY OF OMNETICS CONNECTOR CORP. THIS DOCUMENT MAY NOT, IN WHOLE OR IN PART, BE DUPLICATED, OR DISCLOSED FOR ANY PURPOSE, WITHOUT WRITTEN PERMISSION FROM OMNETICS CONNECTOR CORP. DATE .070 1.78 (15) PIN MALE Bi-Lobe® CONNECTOR 61873 MNETICS O A28100-015 CAGE CODE DWG NO. CONNECTOR CORPORATION 7260 COMMERCE CIRCLE EAST MINNEAPOLIS, MN 55432 WWW.OMNETICS.COM SHEET 1 OF 1 SCALE: 3:1 REV G
A28100-015 价格&库存
很抱歉,暂时无法提供与“A28100-015”相匹配的价格&库存,您可以联系我们找货
