A28500-021
A28500-021
    OMNETICS
    SMD
    21 位 D 型,Nano-D 插头,公引脚 连接器
A28500-021 数据手册
A 2 8 5 0 0 -0 2 1 PART NO. M A T E R IA L S & S P E C IF IC A T IO N S H O U S IN G : A L U M IN U M 6 0 6 1 -T 6 , N IC K E L P L A T E P E R A M S -C -2 6 0 7 4 REV ECO DATE APP H 977 33 06- 27- 11 T LM .3 1 0 7 .8 7 INSULATOR: L IQ U ID C R Y S T A L P O L Y M E R ( L C P ) PER ASTM D5138 CONTACT: B E R Y L L IU M C O P P E R P E R A S T M B194, C 17200, G O LD PLATED P E R A S T M B 4 8 8 , (H A R D G O L D ) T Y P E II C O D E C , C L A S S 1 .2 7 1 11 2X # 0 - 8 0 U N F -2 A .0 4 0 1 .0 2 A .0 5 7 5 1 .4 6 1 12 A .0 9 5 2 .4 1 .0 1 2 5 0 .3 2 HARDWARE: 3 0 3 S T A IN L E S S S T E E L P E R ASTM 582 .0 5 7 1 .4 4 1 .1 2 5 3 .1 8 21 A TERMINATION: S O L D E R C O A T E D W IT H S N 6 3 A P E R J -S T D -0 0 6 O R A M S -P -8 1 7 2 8 .1 0 5 2 .6 7 .2 1 0 5 .3 3 .0 7 1 .8 S E C T IO N A -A V IE W L E S S H A R D W A R E .4 2 0 1 0 .6 7 C U R R E N T R A T IN G : 1 A M P M A X P E R M IL -D T L -3 2 1 3 9 C O N T AC T R E S I S T AN C E : 7 1 M IL L IO H M M A X (7 1 m V D R O P M A X ) @ 1 .0 A M P S P E R M IL D T L -3 2 1 3 9 2 X .0 8 5 2 .1 6 .5 2 5 1 3 .3 4 PERFORMANCE: P R O D U C T F A M IL Y T E S T E D T O A N D PASSED THE PERFORM ANCE S P E C IF IC A T IO N S O F T A B L E V III O F M IL -D T L -3 2 1 3 9 .0 2 8 0 .7 2 .0 8 0 2 .0 3 2X .0 0 8 X .0 0 2 5 (T Y P ) [.2 0 X .0 6 4 ] SOLDER CO ATED M N P O SLDW A C T U A L S IZ E T H IS D R A W IN G C O N T A I N S C O N F I D E N T IA L A N D P R O P R IE T A R Y IN F O R M A T IO N W H IC H I S T H E P R O P E R T Y O F O M N E T IC S C O N N E C T O R C O R P . T H IS D O C U M E N T M A Y N O T , IN W H O L E O R IN P A R T , B E D U P L IC A T E D , O R D IS C L O S E D F O R A N Y P U R P O S E , W I T H O U T W R IT T E N P E R M IS S IO N F R O M O M N E T IC S C O N N E C T O R C O R P . U N L E S S O T H E R W IS E N O T E D D IM E N S IO N S IN IN C H E S 2 PL DEC 3 PL DEC 4 PL DEC AN G LE S .01 .005 .0005 1 1 .0 5 7 1 .4 4 DATE DFTM. AAS 0 5 -0 5 - 0 4 DATE CHK'D. DATE APP'D. . 0 1 2 5 (T Y P ) 0 .3 1 8 .1 0 0 2 .5 4 . 0 2 5 (T Y P ) 0 .6 4 .4 2 0 1 0 .6 7 .3 2 0 8 .1 3 1 -T O L E R A N C E S - .0 1 6 (T Y P ) .0 1 3 0 .4 1 0 .3 3 . 2 5 MAX 6 . 2 MAX .0 2 0 0 .5 1 T H IR D A N G L E .2 5 0 6 .3 5 TITLE: (21) PIN MALE Bi-LoBE® CONNECTOR - T A IL D IM E N S IO N S A P P L Y A T P L A N E A 61873 M N E T I C S O A 2 8 5 0 0 -0 2 1 CAGE CODE DW G NO. CONNECTOR CORPORATION 7 2 6 0 C O M M E R C E C IR C L E E A S T M IN N E A P O L IS , M N 5 5 4 3 2 WWW.OMNETICS.COM SHEET 1 OF 1 REV S C A L E : 3 :1 H
A28500-021 价格&库存
很抱歉,暂时无法提供与“A28500-021”相匹配的价格&库存,您可以联系我们找货
