A29100-021
PART NO.
MATERIALS & SPECIFICATIONS
HOUSING:
ALUMINUM 6061-T6, NICKEL PLATE
PER SAE-AMS-2404
.010 (TYP)
0.25
SOLDER COATED
INSULATOR:
LIQUID CRYSTAL POLYMER (LCP) PER
ASTM D5138
CONTACTS:
COPPER ALLOY PER MIL-DTL-32139,
GOLD PLATED PER ASTM B488,
(HARD GOLD) TYPE II CODE C CLASS
1.27
TERMINATIONS:
SOLDER COATED WITH SN63A
PER J-STD-006
.087
2.21
CURRENT RATING:
1 AMP MAX PER MIL-DTL-32139
.420
10.67
CONTACT RESISTANCE:
71 MILLIOHM MAX (71mV DROP MAX)
@ 1.0 AMPS PER MIL-DTL-32139
.187
4.75
.525
13.34
PERFORMANCE:
PRODUCT FAMILY TESTED TO AND
PASSED THE PERFORMANCE
SPECIFICATIONS OF TABLE VIII OF
MIL-DTL-32139
.313
7.95
12
2X #0-80
UNF-2B
ACTUAL SIZE
.006 A
MNSO SLDW
DIMENSIONS IN [ ] ARE IN
MILLIMETERS UNLESS
OTHERWISE NOTED AND ARE
FOR REFERENCE ONLY
TLM
.042 MIN
1.07
(TYP)
.050
1.27
2X
.085
2.16
.250
6.35
.070
1.78
.420
10.67
.110
2.79
.070 (TYP)
1.78
.040
1.02
.098
2.49
B
11
A
SECTION A-A
.420
10.67
DETAIL B
SCALE 10 : 1
NOTE:
05-03-16
.074
1.88
.125
3.18
.320
8.13
102551
1
.0125
0.318
.140
3.56
.0575
1.461
K
SUGGESTED PAD LAYOUT
A
A
APP
12
21
1
DATE
.017
0.43
(TYP)
.137
3.48
.225
5.72
ECO
.225
5.72
.085
2.16
2X #0-80
UNF-2B
REV
THIRD ANGLE
-TOLERANCESUNLESS OTHERWISE NOTED
DIMENSIONS IN INCHES
2 PL DEC
3 PL DEC
4 PL DEC
ANGLES
.01
.005
.0005
1
CAGE CODE
DWG NO.
THIS DRAWING CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION WHICH IS THE PROPERTY OF
OMNETICS CONNECTOR CORP. THIS DOCUMENT MAY NOT, IN WHOLE OR IN PART, BE DUPLICATED, OR
DISCLOSED FOR ANY PURPOSE, WITHOUT WRITTEN PERMISSION FROM OMNETICS CONNECTOR CORP.
DFTM. AAS 05-10-04 TITLE:
(21) SOCKET FEMALE
DATE
CHK'D.
APP'D.
DATE
DATE
Bi-Lobe® CONNECTOR
7260 COMMERCE CIRCLE EAST
MINNEAPOLIS, MN 55432
WWW.OMNETICS.COM
61873
A29100-021
SHEET 1 OF 1
REV
SCALE: 3:1
K
很抱歉,暂时无法提供与“A29100-021”相匹配的价格&库存,您可以联系我们找货
