PART NO.
MATERIALS & SPECIFICATIONS
.270
6.86
HOUSING:
ALUMINUM 6061-T6, NICKEL
PLATE PER SAE-AMS-2404
INSULATOR:
LIQUID CRYSTAL POLYMER (LCP)
PER ASTM D5138
.050
1.27
.018
0.46
.016
(TYP)
.013
0.41
0.33
N
102438
03-16-16
TLM
.110
2.79
.070 (TYP)
1.78
.125
3.18
.098
2.49
A
1
.010±.002 (TYP)
0.25±0.05
SOLDER COATED
.050 (TYP)
1.27
6
7
.018
0.46
.274
6.96
2
1
SUGGESTED HOLE PATTERN
PIN OUT
2X #0-80
UNF-2B
.070
1.78
.270
6.86
2X
MNSO SLDW
DIMENSIONS IN [ ] ARE IN
MILLIMETERS UNLESS
OTHERWISE NOTED AND ARE
FOR REFERENCE ONLY
.0575
1.461
5
1
.375
9.53
1
1
NOTE:
2X #0-80
UNF-2B
9
.270
6.86
.025
0.64
.050 (TYP)
1.27
.085
2.16
.100
2.54
6
.040
1.02
.0125
0.318
PERFORMANCE:
PRODUCT FAMILY TESTED TO AND
PASSED THE PERFORMANCE
SPECIFICATIONS OF TABLE VIII OF
MIL-DTL-32139
.038
0.95
APP
.11
2.8
CONTACT RESISTANCE:
71 MILLIOHM MAX (71mV DROP
MAX) @ 1.0 AMPS PER MILDTL-32139
.013
0.32
DATE
ACTUAL SIZE
.163
4.14
CURRENT RATING:
1 AMP MAX PER MIL-DTL-32139
ECO
.345
8.76
TERMINATION:
SOLDER COATED WITH SN63A
PER J-STD-006
.140
3.56
REV
.0525
1.334
.458
11.63
CONTACTS:
COPPER ALLOY PER MIL-DTL32139, GOLD PLATED PER ASTM
B488, (HARD GOLD) TYPE II
CODE C, CLASS 1.27
A29400-009
THIRD ANGLE
-TOLERANCESUNLESS OTHERWISE NOTED
DIMENSIONS IN INCHES
2 PL DEC
3 PL DEC
4 PL DEC
ANGLES
.01
.005
.0005
1
.025 (TYP)
0.64
.050 (TYP)
1.27
1 TAIL DIMENSIONS APPLY AT PLANE
CAGE CODE
DWG NO.
THIS DRAWING CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION WHICH IS THE PROPERTY OF
OMNETICS CONNECTOR CORP. THIS DOCUMENT MAY NOT, IN WHOLE OR IN PART, BE DUPLICATED, OR
DISCLOSED FOR ANY PURPOSE, WITHOUT WRITTEN PERMISSION FROM OMNETICS CONNECTOR CORP.
DFTM. SKP 12-29-04 TITLE:
(9) SOCKET FEMALE
DATE
CHK'D.
APP'D.
DATE
DATE
Bi-Lobe® CONNECTOR
7260 COMMERCE CIRCLE EAST
MINNEAPOLIS, MN 55432
WWW.OMNETICS.COM
A
61873
A29400-009
SHEET 1 OF 1
REV
SCALE: 2:1
N
很抱歉,暂时无法提供与“A29400-009”相匹配的价格&库存,您可以联系我们找货
