A29500-015
A29500-015
    OMNETICS
    SMD
    15 位 D 型,Nano-D 插座,母型插口 连接器
A29500-015 数据手册
PART NO. MATERIALS & SPECIFICATIONS A29500-015 REV ECO DATE APP J 102606 05-19-16 TLM HOUSING: ALUMINUM 6061-T6, NICKEL PLATE PER SAE-AMS-2404 INSULATOR: LIQUID CRYSTAL POLYMER (LCP) PER ASTM D5138 CONTACTS: COPPER ALLOY PER MIL-DTL32139, GOLD PLATED PER ASTM B488, (HARD GOLD) TYPE II CODE C, CLASS 1.27 .245 6.22 .010±.002 (TYP), 0.25±0.05 SOLDER COATED .016 (TYP) .013 0.41 0.33 .020 0.51 TERMINATION: SOLDER COATED WITH SN63A PER J-STD-006 .07 1.8 .225 5.72 CURRENT RATING: 1 AMP MAX PER MIL-DTL32139 .025 (TYP) 0.64 .020 0.51 .085 2.16 2X 1 .070 1.78 .040 1.02 .175 4.45 .345 8.76 .450 11.43 CONTACT RESISTANCE: 71 MILLIOHM MAX (71mV DROP MAX) @ 1.0 AMPS PER MIL-DTL-32139 .0125 (TYP) 0.318 SUGGESTED HOLE PATTERN PERFORMANCE: PRODUCT FAMILY TESTED TO AND PASSED THE PERFORMANCE SPECIFICATIONS OF TABLE VIII OF MIL-DTL32139 2X #0-80 UNF-2B .0575 1.461 .238 6.05 9 A 15 .040 1.02 A 1 .110 2.79 8 .0125 0.318 ACTUAL SIZE .070 (TYP) 1.78 .125 3.18 .098 2.49 A 1 .040 1.02 SECTION A-A .345 8.76 NOTES: 1 TAIL DIMENSIONS APPLY AT PLANE A MNSO SLDW DIMENSIONS IN [ ] ARE IN MILLIMETERS UNLESS OTHERWISE NOTED AND ARE FOR REFERENCE ONLY THIRD ANGLE -TOLERANCESUNLESS OTHERWISE NOTED DIMENSIONS IN INCHES 2 PL DEC 3 PL DEC 4 PL DEC ANGLES .01 .005 .0005 1 CAGE CODE DWG NO. THIS DRAWING CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION WHICH IS THE PROPERTY OF OMNETICS CONNECTOR CORP. THIS DOCUMENT MAY NOT, IN WHOLE OR IN PART, BE DUPLICATED, OR DISCLOSED FOR ANY PURPOSE, WITHOUT WRITTEN PERMISSION FROM OMNETICS CONNECTOR CORP. DFTM. AAS 02-17-10 TITLE: (15) SOCKET FEMALE DATE CHK'D. APP'D. DATE DATE Bi-Lobe® CONNECTOR - 7260 COMMERCE CIRCLE EAST MINNEAPOLIS, MN 55432 WWW.OMNETICS.COM 61873 A29500-015 SHEET 1 OF 1 REV SCALE: 3:1 J
A29500-015 价格&库存
很抱歉,暂时无法提供与“A29500-015”相匹配的价格&库存,您可以联系我们找货
