A29500-051
PART NO.
MATERIALS & SPECIFICATIONS
.695
17.65
HOUSING:
ALUMINUM 6061-T6, NICKEL
PLATE PER SAE-AMS-2404
INSULATOR:
LIQUID CRYSTAL POLYMER (LCP)
PER ASTM D5138
.010±.002 (TYP),
0.25±0.05
SOLDER COATED
.07
1.8
REV
ECO
DATE
APP
J
102606
05-19-16
TLM
.020
0.51
CONTACTS:
COPPER ALLOY PER MIL-DTL32139, GOLD PLATED PER ASTM
B488, (HARD GOLD) TYPE II
CODE C, CLASS 1.27
.225
5.72
.016
(TYP)
.013
0.41
0.33
.900
22.86
TERMINATION:
SOLDER COATED WITH SN63A
PER J-STD-006
CURRENT RATING:
1 AMP MAX PER MIL-DTL-32139
.0125 (TYP)
0.318
.025 (TYP)
0.64
.020
0.51
.085
2.16
CONTACT RESISTANCE:
71 MILLIOHM MAX (71mV DROP
MAX) @ 1.0 AMPS PER MILDTL-32139
2X
PERFORMANCE:
PRODUCT FAMILY TESTED TO AND
PASSED THE PERFORMANCE
SPECIFICATIONS OF TABLE VIII OF
MIL-DTL-32139
1
.070
1.78
.040
1.02
.625
15.88
.795
20.19
SUGGESTED HOLE PATTERN
.688
17.48
27
2X #0-80
UNF-2B
.110 (TYP)
2.79
51
.040
1.02
A
.070 (TYP)
1.78
.125
3.18
A
ACTUAL SIZE
A
1
.0575
1.461
.0125
0.318
.795
20.19
NOTES:
1 TAIL DIMENSIONS APPLY
AT PLANE A
MNSO SLDW
DIMENSIONS IN [ ] ARE IN
MILLIMETERS UNLESS
OTHERWISE NOTED AND ARE
FOR REFERENCE ONLY
26
THIRD ANGLE
-TOLERANCESUNLESS OTHERWISE NOTED
DIMENSIONS IN INCHES
2 PL DEC
3 PL DEC
4 PL DEC
ANGLES
.01
.005
.0005
1
.098
2.49
1
SECTION A-A
CAGE CODE
DWG NO.
THIS DRAWING CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION WHICH IS THE PROPERTY OF
OMNETICS CONNECTOR CORP. THIS DOCUMENT MAY NOT, IN WHOLE OR IN PART, BE DUPLICATED, OR
DISCLOSED FOR ANY PURPOSE, WITHOUT WRITTEN PERMISSION FROM OMNETICS CONNECTOR CORP.
DFTM. AAS 05-10-04 TITLE:
(51) SOCKET FEMALE
DATE
CHK'D.
APP'D.
DATE
DATE
.040
1.02
Bi-Lobe® CONNECTOR
7260 COMMERCE CIRCLE EAST
MINNEAPOLIS, MN 55432
WWW.OMNETICS.COM
61873
A29500-051
SHEET 1 OF 1
REV
SCALE: 3:1
J
很抱歉,暂时无法提供与“A29500-051”相匹配的价格&库存,您可以联系我们找货
