A55100-051
A55100-051
    OMNETICS
    SMD
    51 位 D 型,Nano-D 插座,母型插口 连接器
A55100-051 数据手册
PART NO. MATERIALS & SPECIFICATIONS HOUSING: ALUMINUM 6061-T6, NICKEL PLATE PER SAE-AMS-2404 REV ECO DATE APP E 100478 04-21-14 TLM .010 (TYP) 0.25 SOLDER COATED 2X #0-80 UNF-2B INSULATOR: THERMOPLASTIC PER MIL-DTL32139 CONTACTS: COPPER ALLOY PER MIL-DTL32139, GOLD PLATED PER ASTM B488, (HARD GOLD) TYPE II CODE C CLASS 1.27 A55100-051 .087 2.21 .225 5.72 .187 4.75 1.445 36.70 TERMINATIONS: SOLDER COATED WITH SN63A PER J-STD-006 1.550 39.37 .017 0.43 TYP CURRENT RATING: 1 AMP MAX PER MIL-DTL-32139 CONTACT RESISTANCE: 71 MILLIOHM MAX (71mV DROP MAX) @ 1.0 AMPS PER MILDTL-32139 1 .042 MIN 1.07 MIN PERFORMANCE: PRODUCT FAMILY TESTED TO AND PASSED THE PERFORMANCE SPECIFICATIONS OF TABLE VIII OF MIL-DTL-32139 2X .098 2.48 .025 0.64 TYP .070 1.78 .074 1.88 1.250 31.75 1.445 36.70 SUGGESTED PAD LAYOUT 2X #0-80 UNF-2B 1.335 33.91 A .0575 1.461 .110 2.79 .025 0.64 .070 1.78 .115 2.92 ACTUAL SIZE .130 3.30 A 1 1.345 34.16 .075 1.91 51 SECTION A-A 1.445 36.70 SLDW DIMENSIONS IN [ ] ARE IN MILLIMETERS UNLESS OTHERWISE NOTED AND ARE FOR REFERENCE ONLY MBSS NOTE: THIRD ANGLE -TOLERANCESUNLESS OTHERWISE NOTED DIMENSIONS IN INCHES 2 PL DEC 3 PL DEC 4 PL DEC ANGLES .01 .005 .0005 1 THIS DRAWING CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION WHICH IS THE PROPERTY OF OMNETICS CONNECTOR CORP. THIS DOCUMENT MAY NOT, IN WHOLE OR IN PART, BE DUPLICATED, OR DISCLOSED FOR ANY PURPOSE, WITHOUT WRITTEN PERMISSION FROM OMNETICS CONNECTOR CORP. DFTM. TEP 02-27-07 TITLE: (51) SOCKET FEMALE DATE CHK'D. APP'D. DATE DATE Bi-Lobe® CONNECTOR 61873 MNETICS O A55100-051 CONNECTOR CORPORATION 7260 COMMERCE CIRCLE EAST MINNEAPOLIS, MN 55432 WWW.OMNETICS.COM CAGE CODE DWG NO. SHEET 1 OF 1 REV SCALE: 3:1 E
A55100-051 价格&库存
很抱歉,暂时无法提供与“A55100-051”相匹配的价格&库存,您可以联系我们找货
