A79047-001
A79047-001
    OMNETICS
    插件,P=0.64mm
    线对板针座 2x18P 直插 间距:0.64mm
A79047-001 数据手册
PART NO. M A T E R IA L S & S P E C I F I C A T I O N S A 7 9 0 4 7 -0 0 1 REV ECO DATE APP B 991 05 12- 07- 12 T LM INSULATOR: T H E R M O P L A S T IC P E R M IL - M 2 4 5 1 9 , T Y P E G L C P -3 0 F O R G S T 40F N ATURAL CONTACT: C O P P E R A L L O Y P E R M IL -D T L 32139. G O LD PLATED PER ASTM B 4 8 8 , (H A R D G O L D ) T Y P E II C O D E C C L A S S 1 .2 7 (1 8 ) S P A C E S @ .0 2 5 = .4 5 0 [0 .6 4 ] [1 1 .4 3 ] .0 2 0 0 .5 1 TERMINATION: S O L D E R C O A T E D P E R J -S T D -0 0 6 O R P L A T E D P E R A M S -P -8 1 7 2 8 .0 3 0 0 .7 6 .0 7 0 1 .7 8 A C T U A L S IZ E G U ID E P O S T: B E R Y L L IU M C O P P E R A L L O Y P E R A S T M B 1 9 6 . E L E C T R O L E S S N IC K E L P E R S A E -A M S -2 4 0 4 CU RRENT CAPAC ITY: 1 A M P M A X P E R M IL -D T L -3 2 1 3 9 CONTACT RESISTANCE: 7 1 M IL L IO H M S (7 1 m V ) M A X @ 1 .0 A M P S P E R M IL -D T L -3 2 1 3 9 .4 9 1 2 .4 2 X G U ID E P O S T .0 6 1 .6 .0 9 3 ± .0 1 0 2 .3 6 ± 0 .2 5 .1 0 0 2 .5 4 .1 0 2 .5 . 0 0 8 SOLDER COATED 0 .2 0 SLDW D IM E N S IO N S IN [ ] A R E IN M IL L IM E T E R S U N L E S S O T H E R W IS E N O T E D A N D A R E FOR REFERENCE ONLY T H IR D A N G L E NSD NOT E: -T O L E R A N C E S - T H IS D R A W IN G C O N T A I N S C O N F I D E N T IA L A N D P R O P R IE T A R Y IN F O R M A T IO N W H IC H I S T H E P R O P E R T Y O F O M N E T IC S C O N N E C T O R C O R P . T H IS D O C U M E N T M A Y N O T , IN W H O L E O R IN P A R T , B E D U P L IC A T E D , O R D IS C L O S E D F O R A N Y P U R P O S E , W I T H O U T W R IT T E N P E R M IS S IO N F R O M O M N E T IC S C O N N E C T O R C O R P . U N L E S S O T H E R W IS E N O T E D D IM E N S IO N S IN IN C H E S 2 PL DEC 3 PL DEC 4 PL DEC AN G LE S .01 .005 .0005 1 DATE D F TM . D G J 0 9 -1 2 - 1 1 DATE CHK'D. DATE APP'D. TITLE: (36) SOCKET FEMALE DUAL ROW NANO CONNECTOR W/GUIDE POSTS 61873 M N E T I C S O A 7 9 0 4 7 -0 0 1 CAGE CODE DW G NO. CONNECTOR CORPORATION 7 2 6 0 C O M M E R C E C IR C L E E A S T M IN N E A P O L IS , M N 5 5 4 3 2 WWW.OMNETICS.COM SHEET 1 OF 1 REV S C A L E : 5 :1 B
A79047-001 价格&库存
很抱歉,暂时无法提供与“A79047-001”相匹配的价格&库存,您可以联系我们找货
