8D009M35SN-LC
8D009M35SN-LC
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    6 针位圆形连接器 插座外壳 面板安装
8D009M35SN-LC 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal P 3.25±0.2 PP 5.49±0.2 R1 18.26 R2 15.09 S 23.8±0.3 V' 19.5+1.4/-0 W' 2.1/3.65 Z' 32 Max VV THREAD M12x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Composite -Shell Plating : Nickel -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D009M35SNL -Delivered without Souriau contacts -Temperature Range -Salt Spray : -65°C to +200°C : 2000 hours -Mass : 7.9 g ± 10% A 03-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D SHELL TYPE : Square Flange Receptacle CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 09 PLATING : M = Jurisdiction & Control List Not Listed 0 - 09 M 35 S N SCALE L Delivered W/O Contacts ORIENTATION : N NA SOURIAU Latest modification - by Composite Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : SOCKET(500 Matings) Nickel CONTACT LAYOUT : 09-35 FORMAT A3 MOD N° CUSTOMER DRAWING Date: SOURIAU DRG N° 8D009M35SNL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout Panel Cutout Dim ØA ØAA R1 ØT Nominal 16.66 min 13.11 min 18.26 3.25 ±0.13 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D009M35SNL A 03-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D009M35SNL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D009M35SN-LC
- 物料型号: 8D009M35SNL - 器件简介: 该插座基于MIL-DTL-38999系列III标准,采用硅橡胶密封和复合材料壳体,具有镀镍绝缘体和铜合金接触件,表面镀金。 - 引脚分配: 有9个接触点的布局,具体布局未在摘要中详细说明。 - 参数特性: - 尺寸参数: 提供了包括外径(P, PP)、R1, R2, S, V, W, Z等的尺寸和公差。 - 螺纹规格: M12x1-6g。 - 耐久性: 500次配对周期。 - 温度范围: -65°C至+200°C。 - 盐雾测试: 2000小时。 - 重量: 7.9克±10%。 - 功能详解: 插座设计用于满足特定的电气连接需求,具有高耐久性和宽温度范围。 - 应用信息: 适用于需要高可靠性和环境耐受性的场合。 - 封装信息: 提供了面板切口的尺寸和公差。
8D009M35SN-LC 价格&库存
很抱歉,暂时无法提供与“8D009M35SN-LC”相匹配的价格&库存,您可以联系我们找货
