8D011F35PC-LC
8D011F35PC-LC
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D 13C 13#22D PIN RECP
8D011F35PC-LC 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal P 3.25±0.2 PP 4.93±0.2 R1 20.62 R2 18.26 S 26.2±0.3 V 20.83+0/-1.25 W 2.1/2.5 Z 31.5 Max VV THREAD M15x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Aluminium -Shell Plating : Nickel -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D011F35PCL -Delivered without Souriau contacts -Temperature Range -Salt Spray : -65°C to +200°C : 48 hours -Mass : 10.85 g ± 10% A 14-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D SHELL TYPE : Square Flange Receptacle CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 11 PLATING : F = Jurisdiction & Control List Not Listed 0 - 11 F 35 P C SCALE L Delivered W/O Contacts ORIENTATION : C NA SOURIAU Latest modification - by Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : PIN(500 Matings) Nickel CONTACT LAYOUT : 11-35 FORMAT A3 MOD N° CUSTOMER DRAWING Date: SOURIAU DRG N° 8D011F35PCL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout Panel Cutout Dim ØA ØAA R1 ØT Nominal 20.22 min 15.88 min 20.62 3.25 ±0.13 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D011F35PCL A 14-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D011F35PCL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D011F35PC-LC
1. 物料型号:8D011F35PCL-C 2. 器件简介:这是一个铝制插座,属于SOURIAU的8D系列。它是一个方形法兰插座,设计用于标准压接接触。 3. 引脚分配:接触布局为11-35,意味着有35个引脚,按照11×3的排列方式。 4. 参数特性: - 标准:基于MIL-DTL-38999系列III - 壳体材料:铝,表面镀镍 - 绝缘体:热塑性塑料 - 接触材料:铜合金 - 密封和垫圈:硅橡胶 - 耐久性:500次配对循环 - 质量:10.85克±10% - 温度范围:-65°C至+200°C - 盐雾测试:48小时 5. 功能详解:该插座设计用于多种应用,具有高耐久性和广泛的温度适应性。它还符合特定的军事标准。 6. 应用信息:文档中没有提供具体的应用案例,但可以推断它适用于需要高可靠性和环境适应性的电子设备。 7. 封装信息:该插座的封装类型为方形法兰插座,具有特定的尺寸和公差,如壳体直径、法兰直径和面板切口尺寸。
8D011F35PC-LC 价格&库存
很抱歉,暂时无法提供与“8D011F35PC-LC”相匹配的价格&库存,您可以联系我们找货
