8D011W22SA-LC
8D011W22SA-LC
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D 4C 4#22D SKT RECP
8D011W22SA-LC 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal P 3.25±0.2 PP 4.93±0.2 R1 20.62 R2 18.26 S 26.2±0.3 V 20.83+0/-1.25 W 2.1/2.5 Z 31.5 Max VV THREAD M15x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Aluminium -Shell Plating : Olive drab Cadmium -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D011W22SAL -Delivered without Souriau contacts -Temperature Range -Salt Spray : -65°C to +175°C : 500 hours -Mass : 12.92 g ± 10% A 08-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D SHELL TYPE : Square Flange Receptacle CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 11 PLATING : W = Jurisdiction & Control List Not Listed 0 - 11 W 22 S A SCALE L Delivered W/O Contacts ORIENTATION : A NA SOURIAU Latest modification - by Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : SOCKET(500 Matings) Olive drab Cadmium CONTACT LAYOUT : 11-22 FORMAT A3 MOD N° CUSTOMER DRAWING Date: SOURIAU DRG N° 8D011W22SAL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout Panel Cutout Dim ØA ØAA R1 ØT Nominal 20.22 min 15.88 min 20.62 3.25 ±0.13 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D011W22SAL A 08-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D011W22SAL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D011W22SA-LC
物料型号:8D011W22SAL 器件简介:SOURIAU品牌的8D系列,11号方形法兰插座,具有标准夹接接触件,用于500次插拔。
引脚分配:11-22引脚布局,其中A引脚位于(1.905, 1.905),B引脚位于(1.905, -1.905),C引脚位于(-1.905, -1.905),D引脚位于(-1.905, 1.905)。
参数特性:产品符合MIL-DTL-38999系列III标准,采用铜合金镀金(至少0.8µm)的接触件,硅橡胶绝缘体,铝制外壳,热塑性橄榄绿外壳,镀镉铜合金接触件,工作温度范围为-65°C至+175°C,耐盐雾500小时,插拔寿命500次。
功能详解:提供高可靠性的连接,适用于恶劣环境,如军事、航空航天和工业应用。
应用信息:用于需要高插拔次数和耐环境侵蚀的应用场景。
封装信息:尺寸参数包括P(3.25±0.2),PP(4.93±0.2),R1(20.62),R2(18.26),S(26.2±0.3),V(20.83+0/-1.25),W(2.1/2.5),螺纹规格为M15x1-6g。
8D011W22SA-LC 价格&库存
很抱歉,暂时无法提供与“8D011W22SA-LC”相匹配的价格&库存,您可以联系我们找货
