8D013J35SN
8D013J35SN
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D 22C 22#22D SKT RECP
8D013J35SN 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal P 3.25±0.2 PP 4.93±0.2 R1 23.01 R2 20.62 S 28.6±0.3 V' 19.5+1.4/-0 W' 2.1/3.65 Z' 32 Max VV THREAD M18x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Composite -Shell Plating : Olive drab Cadmium -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D013J35SN -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +175°C : 2000 hours -Mass : 19.6 g ± 10% A 14-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D 0 - 13 J 35 S SCALE N NA SHELL TYPE : Square Flange Receptacle CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 13 PLATING : J = Jurisdiction & Control List Not Listed ORIENTATION : N SOURIAU Latest modification - by Composite Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : SOCKET(500 Matings) Olive drab Cadmium CONTACT LAYOUT : 13-35 FORMAT A3 MOD N° CUSTOMER DRAWING Date: SOURIAU DRG N° 8D013J35SN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout Panel Cutout Dim ØA ØAA R1 ØT Nominal 23.42 min 19.05 min 23.01 3.25 ±0.13 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D013J35SN A 14-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D013J35SN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D013J35SN 价格&库存
很抱歉,暂时无法提供与“8D013J35SN”相匹配的价格&库存,您可以联系我们找货
8D013J35SN
库存:186
