8D015J05PN
8D015J05PN
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D 5C 5#16 PIN RECP
8D015J05PN 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal P 3.25±0.2 PP 4.39±0.2 R1 24.61 R2 23.01 S 31±0.3 V' 19.5+1.4/-0 W' 2.1/3.65 Z' 32 Max VV THREAD M22x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Composite -Shell Plating : Olive drab Cadmium -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D015J05PN -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +175°C : 2000 hours -Mass : 16.6 g ± 10% A 12-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D 0 - 15 J 05 P SCALE N NA SHELL TYPE : Square Flange Receptacle CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 15 PLATING : J = Jurisdiction & Control List Not Listed ORIENTATION : N SOURIAU Latest modification - by Composite Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : PIN(500 Matings) Olive drab Cadmium CONTACT LAYOUT : 15-05 FORMAT A3 MOD N° CUSTOMER DRAWING Date: SOURIAU DRG N° 8D015J05PN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout Panel Cutout Dim ØA ØAA R1 ØT Nominal 26.59 min 23.01 min 24.61 3.25 ±0.13 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D015J05PN A 12-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D015J05PN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D015J05PN 价格&库存
很抱歉,暂时无法提供与“8D015J05PN”相匹配的价格&库存,您可以联系我们找货
8D015J05PN
库存:17
8D015J05PN
  • 1+583.759051+72.43600
  • 10+505.9217210+62.77752
库存:17
