LAYOUT SHOWN AS EXAMPLE
Keying Shown as example
CHARACTERISTICS
Connector dimension
Dim
Nominal
P
3.25±0.2
PP
4.93±0.2
R1
26.97
R2
24.61
S
33.3±0.3
V'
19.5+1.4/-0
W'
2.1/3.65
Z'
32 Max
VV THREAD
M25x1-6g
-Standard : Based on MIL-DTL-38999 Series III
-Shell Material
: Composite
-Shell Plating
: Olive drab Cadmium
-Insulator
: Thermoplastic
-Contacts
: Copper Alloy
-Seals & Grommet
: Silicon Elastomer
-Contact Plating
: Gold over copper Alloy 0.8µm minimum
-Durability
: 500 Mating cycles
SOURIAU shall not be liable for any non-conformity or damage
due to a use of the Products which does not comply with
the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
Country
FR
PN: 8D017J26PBL
-Delivered without Souriau contacts
-Temperature Range
-Salt Spray
: -65°C to +175°C
: 2000 hours
-Mass
: 19.2 g ± 10%
B
10-04-17 Drawing Update
ISS
DATE
Designed By:
TITLE
BASIC SERIES:
8D
SHELL TYPE : Square Flange Receptacle
CONTACT TYPE
: Standard Crimp Contact
SHELL SIZE : 17
PLATING
J =
Jurisdiction & Control List
Not Listed
J
26
P
B
SCALE
L
Delivered W/O Contacts
ORIENTATION : B
NA
SOURIAU
Latest modification - by
Composite Receptacle 8D series
General linear
Tolerances:
WWW.SOURIAU.COM
CONTACT TYPE : PIN(500 Matings)
Olive drab Cadmium
CONTACT LAYOUT : 17-26
FORMAT
A3
MOD N°
CUSTOMER DRAWING
Date:
SOURIAU DRG N°
8D017J26PBL-C
NPRDS / PROJECT
859
This document is the property of
SOURIAU
it must not be reproduced or
communicated without permission
SHEET
1/2
Contact Layout
Panel Cutout
Max. thickness panel for receptacle: Type 0: front mounting = 3.2 mm, rear mounting = 2.5 mm
Dim
ØA
ØAA
R1
ØT
Nominal
30.96 min
25.81 min
26.97
3.25 ±0.13
Country
FR
Not Listed
PN: 8D017J26PBL
B
ISS
DATE
Designed By:
TITLE
SCALE
NA
SOURIAU
FORMAT
A3
MOD N°
CUSTOMER DRAWING
Date:
General linear
Tolerances:
WWW.SOURIAU.COM
SOURIAU DRG N°
8D017J26PBL-C
NPRDS / PROJECT
859
SOURIAU
SHEET
2/2
很抱歉,暂时无法提供与“8D017J26PB-LC”相匹配的价格&库存,您可以联系我们找货
