8D017M08SB
8D017M08SB
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D 8C 8#16 SKT RECP
8D017M08SB 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal P 3.25±0.2 PP 4.93±0.2 R1 26.97 R2 24.61 S 33.3±0.3 V' 19.5+1.4/-0 W' 2.1/3.65 Z' 32 Max VV THREAD M25x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Composite -Shell Plating : Nickel -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D017M08SB -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +200°C : 2000 hours -Mass : 30.1 g ± 10% B 11-04-17 Drawing Update ISS DATE Designed By: TITLE BASIC SERIES: 8D 0 - 17 M 08 S SCALE B NA SHELL TYPE : Square Flange Receptacle CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 17 PLATING : M = Jurisdiction & Control List Not Listed ORIENTATION : B SOURIAU Latest modification - by Composite Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : SOCKET(500 Matings) Nickel CONTACT LAYOUT : 17-08 FORMAT A3 MOD N° CUSTOMER DRAWING Date: SOURIAU DRG N° 8D017M08SB-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout Panel Cutout Max. thickness panel for receptacle: Type 0: front mounting = 3.2 mm, rear mounting = 2.5 mm Dim ØA ØAA R1 ØT Nominal 30.96 min 25.81 min 26.97 3.25 ±0.13 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D017M08SB B 11-04-17 Drawing Update ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D017M08SB-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D017M08SB 价格&库存
很抱歉,暂时无法提供与“8D017M08SB”相匹配的价格&库存,您可以联系我们找货
