8D019F11BN
8D019F11BN
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D 11C 11#16 SKT RECP
8D019F11BN 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal P 3.25±0.2 PP 4.93±0.2 R1 29.36 R2 26.97 S 36.5±0.3 V 20.83+0/-1.25 W 2.1/2.5 Z 31.5 Max VV THREAD M28x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Aluminium -Shell Plating : Nickel -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D019F11BN -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +200°C : 48 hours -Mass : 44.66 g ± 10% A 08-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D 0 - 19 F 11 B SCALE N NA SHELL TYPE : Square Flange Receptacle CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 19 PLATING : F = Jurisdiction & Control List Not Listed ORIENTATION : N SOURIAU Latest modification - by Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : SOCKET(500 Matings) Nickel CONTACT LAYOUT : 19-11 FORMAT A3 MOD N° CUSTOMER DRAWING Date: SOURIAU DRG N° 8D019F11BN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout Panel Cutout Dim ØA ØAA R1 ØT Nominal 32.96 min 28.98 min 29.36 3.25 ±0.13 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D019F11BN A 08-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D019F11BN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D019F11BN 价格&库存
很抱歉,暂时无法提供与“8D019F11BN”相匹配的价格&库存,您可以联系我们找货
8D019F11BN
库存:28
