8D025W17PN-LC
8D025W17PN-LC
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D 42C 36#22D 6#8 PIN RECP
8D025W17PN-LC 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal P 3.91±0.2 PP 6.15±0.2 R1 38.1 R2 34.93 S 46±0.3 V 20.07+0/-1.25 W 2.1/3.2 Z 31.5 Max VV THREAD M37x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Aluminium -Shell Plating : Olive drab Cadmium -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D025W17PNL -Delivered without Souriau contacts -Temperature Range -Salt Spray : -65°C to +175°C : 500 hours A 08-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D SHELL TYPE : Square Flange Receptacle CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 25 PLATING : W = Jurisdiction & Control List Not Listed 0 - 25 W 17 P N SCALE L Delivered W/O Contacts ORIENTATION : N NA SOURIAU Latest modification - by Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : PIN(500 Matings) Olive drab Cadmium CONTACT LAYOUT : 25-17 FORMAT A3 MOD N° CUSTOMER DRAWING Date: SOURIAU DRG N° 8D025W17PNL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout Panel Cutout Dim ØA ØAA R1 ØT Nominal 42.47 min 37.69 min 38.1 3.81 ±0.13 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D025W17PNL A 08-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D025W17PNL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D025W17PN-LC 价格&库存
很抱歉,暂时无法提供与“8D025W17PN-LC”相匹配的价格&库存,您可以联系我们找货
