8D511K35PN-LC
8D511K35PN-LC
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D 13C 13#22D PIN PLUG
8D511K35PN-LC 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal ØS 25 Max Z 31 Max VV THREAD M15x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Stainless Steel -Shell Plating : Passivated -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D511K35PNL -Delivered without Souriau contacts -Temperature Range -Salt Spray : -65°C to +200°C : 500 hours -Mass : 36.97 g ± 10% A 16-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D SHELL TYPE : Plug with RFI Shielding CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 11 PLATING : K = Jurisdiction & Control List Not Listed 5 - 11 K 35 P N SCALE L Delivered W/O Contacts ORIENTATION : N NA SOURIAU Latest modification - by MOD N° CUSTOMER DRAWING Date: Stainless Steel Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : PIN(500 Matings) Passivated CONTACT LAYOUT : 11-35 FORMAT A3 SOURIAU DRG N° 8D511K35PNL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D511K35PNL A 16-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Stainless Steel Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D511K35PNL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D511K35PN-LC
- 物料型号: 8D511K35PNL-C - 器件简介: 该物料是SOURIAU公司生产的不锈钢插头,属于8D系列。 - 引脚分配: 该插头具有35个接触点,具体的引脚布局在文档中以表格形式展示。 - 参数特性: - 标准:基于MIL-DTL-38999系列III - 壳体材料:不锈钢 - 壳体镀层:钝化处理 - 接触材料:铜合金 - 密封件和垫圈:硅橡胶 - 接触镀层:至少0.8微米的金层 - 耐久性:500次配对周期 - 重量:36.97克±10% - 温度范围:-65°C至+200°C - 盐雾测试:500小时 - 功能详解: 该插头设计用于射频干扰屏蔽,具有标准压接接触,适用于多种电气连接。 - 应用信息: 该物料被归类在国家管辖和控制列表之外,未列出。 - 封装信息: 该插头为不锈钢材质,带有射频干扰屏蔽,提供了详细的尺寸和公差信息。
8D511K35PN-LC 价格&库存
很抱歉,暂时无法提供与“8D511K35PN-LC”相匹配的价格&库存,您可以联系我们找货
