8D019W28SC-LC
8D019W28SC-LC
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D 28C 26#20 2#16 SKT RECP
8D019W28SC-LC 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal P 3.25±0.2 PP 4.93±0.2 R1 29.36 R2 26.97 S 36.5±0.3 V 20.83+0/-1.25 W 2.1/2.5 Z 31.5 Max VV THREAD M28x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Aluminium -Shell Plating : Olive drab Cadmium -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D019W28SCL -Delivered without Souriau contacts -Temperature Range -Salt Spray : -65°C to +175°C : 500 hours A 02-11-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D SHELL TYPE : Square Flange Receptacle CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 19 PLATING : W = Jurisdiction & Control List Not Listed 0 - 19 W 28 S C SCALE L Delivered W/O Contacts ORIENTATION : C NA SOURIAU Latest modification - by Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : SOCKET(500 Matings) Olive drab Cadmium CONTACT LAYOUT : 19-28 FORMAT A3 MOD N° CUSTOMER DRAWING Date: SOURIAU DRG N° 8D019W28SCL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout Panel Cutout Dim ØA ØAA R1 ØT Nominal 32.94 min 28.98 min 29.36 3.25 ±0.13 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D019W28SCL A 02-11-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D019W28SCL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D019W28SC-LC
物料型号为8D019W28SCL,属于SOURIAU品牌的8D系列,是一个带方法兰插座的产品。
器件简介指出,该连接器的绝缘体为硅橡胶,接触件为铜合金,接触镀层为金层,最小厚度0.8微米,壳体材料为铝合金,壳体镀层为橄榄色镉。
该连接器符合MIL-DTL-38999系列III标准,未配备SOURIAU接触件,具有500次的插拔耐久性,能在-65°C至+175°C的温度范围内工作500小时。
引脚分配为19-28,即有19到28个接触位。
参数特性包括多种尺寸,如P(3.25±0.2mm)、PP(4.93±0.2mm)、R1(29.36mm)、R2(26.97mm)、S(36.5±0.3mm)、V(20.83±1.25mm)、W(2.1/2.5mm)和z(31.5mm最大)。
螺纹规格为M28x1-6g。
功能详解包括连接器的密封和防尘性能,以及对盐雾和耐久性的抵抗力。
应用信息说明该连接器适用于需要高可靠性和环境适应性的应用场合。
封装信息显示,该连接器为带方法兰插座型,未配备接触件,具有标准压接接触件和500次插拔寿命的插座。
文档还提供了详细的尺寸和安装信息。
8D019W28SC-LC 价格&库存
很抱歉,暂时无法提供与“8D019W28SC-LC”相匹配的价格&库存,您可以联系我们找货
