8D511M35JN
8D511M35JN
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    13 针位圆形连接器 插头,母插口 压接
8D511M35JN 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal ØS 25 Max Z' 31.5 Max VV THREAD M15x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Composite -Shell Plating : Nickel -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D511M35JN -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +200°C : 2000 hours A 17-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D 5 - 11 M 35 J SCALE N NA SHELL TYPE : Plug with RFI Shielding CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 11 PLATING : M = Jurisdiction & Control List Not Listed ORIENTATION : N SOURIAU Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : SOCKET (1500 Matings) Nickel CONTACT LAYOUT : 11-35 FORMAT A3 SOURIAU DRG N° 8D511M35JN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D511M35JN A 17-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D511M35JN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D511M35JN
- 物料型号: 8D511M35JN-C - 器件简介: 这是一个符合MIL-DTL-38999系列III标准的连接器,具有500次配对周期的耐用性,工作温度范围为-65°C至+200°C,耐盐雾时间达2000小时。 - 引脚分配: 包含11个引脚,布局编号为11-35。 - 参数特性: 包括接触镀层为铜上镀金,最小厚度0.8微米;密封和垫圈材料为硅橡胶;外壳材质为复合材料;外壳镀镍;绝缘体为热塑性材料。 - 功能详解: 提供了详细的尺寸信息,如最大尺寸“as”为25mm,最大尺寸“Z”为31.5mm,螺纹规格为M15x1-6g。 - 应用信息: 用于需要射频屏蔽的插头,由SOURIAU设计,符合专业推荐或技术通知的规格。 - 封装信息: 标准压接接触,插座接触可配对1500次。
8D511M35JN 价格&库存
很抱歉,暂时无法提供与“8D511M35JN”相匹配的价格&库存,您可以联系我们找货
