8D511M98SD
8D511M98SD
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D 6C 6#20 SKT PLUG
8D511M98SD 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal ØS 25 Max Z' 31.5 Max VV THREAD M15x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Composite -Shell Plating : Nickel -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D511M98SD -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +200°C : 2000 hours -Mass : 15.3 g ± 10% A 17-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D 5 - 11 M 98 S SCALE D NA SHELL TYPE : Plug with RFI Shielding CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 11 PLATING : M = Jurisdiction & Control List Not Listed ORIENTATION : D SOURIAU Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : SOCKET(500 Matings) Nickel CONTACT LAYOUT : 11-98 FORMAT A3 SOURIAU DRG N° 8D511M98SD-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D511M98SD A 17-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D511M98SD-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D511M98SD
- 物料型号: 8D511M98SD - 器件简介: 该插头基于MIL-DTL-38999系列III标准,采用复合材料外壳,镍镀层,具有RFI屏蔽功能。 - 引脚分配: 11个接触点,布局为11-98S。 - 参数特性: - 接触材料:铜合金 - 密封和垫圈:硅橡胶 - 接触镀层:至少0.8微米的金层 - 耐久性:500次配对周期 - 质量:15.3克±10% - 温度范围:-65°C至+200°C - 盐雾测试:2000小时 - 功能详解: 提供了详细的尺寸信息,包括最大尺寸和螺纹规格(M15x1-6g)。 - 应用信息: 适用于需要符合MIL-DTL-38999系列III标准的应用,并且符合SOURIAU公司发布的规格。 - 封装信息: 提供了产品的封装类型、尺寸和材料信息。
8D511M98SD 价格&库存
很抱歉,暂时无法提供与“8D511M98SD”相匹配的价格&库存,您可以联系我们找货
