8D513M04PN
8D513M04PN
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    4 针位圆形连接器 插头,公引脚 压接
8D513M04PN 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal ØS 29.4 Max Z' 31.5 Max VV THREAD M18x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Composite -Shell Plating : Nickel -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D513M04PN -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +200°C : 2000 hours -Mass : 17.2 g ± 10% A 18-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D 5 - 13 M 04 P SCALE N NA SHELL TYPE : Plug with RFI Shielding CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 13 PLATING : M = Jurisdiction & Control List Not Listed ORIENTATION : N SOURIAU Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : PIN(500 Matings) Nickel CONTACT LAYOUT : 13-04 FORMAT A3 SOURIAU DRG N° 8D513M04PN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D513M04PN A 18-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D513M04PN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D513M04PN
PDF文档中包含以下内容:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一种集成电路,具有光耦控制功能,用于实现电气隔离。
3. 引脚分配:共8个引脚,分别为1脚光电二极管正极,2脚光电二极管负极,3脚输出,4脚接地,5脚输入,6脚Vcc,7脚输出,8脚Vcc。
4. 参数特性:工作温度范围为-40~85℃,隔离电压为5000Vrms。
5. 功能详解:EL817内部包含一个发光二极管和一个光敏三极管,发光二极管接收电信号后发光,光敏三极管接收光信号后导通。
6. 应用信息:广泛应用于数据通信、测量、工业控制等领域。
7. 封装信息:采用DIP-8封装。
8D513M04PN 价格&库存
很抱歉,暂时无法提供与“8D513M04PN”相匹配的价格&库存,您可以联系我们找货
8D513M04PN
库存:2
