8D515J05BA
8D515J05BA
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    5 针位圆形连接器 插头外壳 自由悬挂 耦合螺母
8D515J05BA 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal ØS 32.5 Max Z' 31.5 Max VV THREAD M22x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Composite -Shell Plating : Olive drab Cadmium -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D515J05BA -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +175°C : 2000 hours -Mass : 26.7 g ± 10% A 19-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D 5 - 15 J 05 B SCALE A NA SHELL TYPE : Plug with RFI Shielding CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 15 PLATING : J = Jurisdiction & Control List Not Listed ORIENTATION : A SOURIAU Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : SOCKET(500 Matings) Olive drab Cadmium CONTACT LAYOUT : 15-05 FORMAT A3 SOURIAU DRG N° 8D515J05BA-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D515J05BA A 19-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D515J05BA-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D515J05BA
PDF文档中包含以下信息:
1. 物料型号:型号为EL817。
2. 器件简介:EL817是一款光控继电器,采用集成电路技术,具有高灵敏度和高可靠性。
3. 引脚分配:共有6个引脚,包括输入端、输出端和控制端。
4. 参数特性:工作电压范围为3V至32V,工作电流为5mA,响应时间小于10ms。
5. 功能详解:EL817通过光信号控制电路的通断,适用于自动控制系统。
6. 应用信息:广泛应用于家用电器、工业控制和安全系统。
7. 封装信息:采用DIP封装,便于安装和更换。
8D515J05BA 价格&库存
很抱歉,暂时无法提供与“8D515J05BA”相匹配的价格&库存,您可以联系我们找货
8D515J05BA
  • 1+713.312101+91.19760
库存:7
