8D515J18SN-LC
8D515J18SN-LC
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D 18C 18#20 SKT PLUG
8D515J18SN-LC 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal ØS 32.5 Max Z' 31.5 Max VV THREAD M22x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Composite -Shell Plating : Olive drab Cadmium -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D515J18SNL -Delivered without Souriau contacts -Temperature Range -Salt Spray : -65°C to +175°C : 2000 hours -Mass : 24 g ± 10% A 19-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D SHELL TYPE : Plug with RFI Shielding CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 15 PLATING : J = Jurisdiction & Control List Not Listed 5 - 15 J 18 S N SCALE L Delivered W/O Contacts ORIENTATION : N NA SOURIAU Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : SOCKET(500 Matings) Olive drab Cadmium CONTACT LAYOUT : 15-18 FORMAT A3 SOURIAU DRG N° 8D515J18SNL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D515J18SNL A 19-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D515J18SNL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D515J18SN-LC 价格&库存
很抱歉,暂时无法提供与“8D515J18SN-LC”相匹配的价格&库存,您可以联系我们找货
