LAYOUT SHOWN AS EXAMPLE
Keying Shown as example
CHARACTERISTICS
Connector dimension
Dim
Nominal
ØS
32.5 Max
Z'
31.5 Max
VV THREAD
M22x1-6g
-Standard : Based on MIL-DTL-38999 Series III
-Shell Material
: Composite
-Shell Plating
: Olive drab Cadmium
-Insulator
: Thermoplastic
-Contacts
: Copper Alloy
-Seals & Grommet
: Silicon Elastomer
-Contact Plating
: Gold over copper Alloy 0.8µm minimum
-Durability
: 500 Mating cycles
SOURIAU shall not be liable for any non-conformity or damage
due to a use of the Products which does not comply with
the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
Country
FR
PN: 8D515J97PA
-Delivered with Souriau contacts and Accessories
-Temperature Range
-Salt Spray
: -65°C to +175°C
: 2000 hours
-Mass
: 21.8 g ± 10%
A
19-10-2016 First Release
ISS
DATE
Designed By:
TITLE
BASIC SERIES:
8D
5
15
J
97
P
SCALE
A
NA
SHELL TYPE : Plug with RFI Shielding
CONTACT TYPE
: Standard Crimp Contact
SHELL SIZE : 15
PLATING
J =
Jurisdiction & Control List
Not Listed
ORIENTATION : A
SOURIAU
Latest modification - by
MOD N°
CUSTOMER DRAWING
Date:
Composite Plug 8D series
General linear
Tolerances:
WWW.SOURIAU.COM
CONTACT TYPE : PIN(500 Matings)
Olive drab Cadmium
CONTACT LAYOUT : 15-97
FORMAT
A3
SOURIAU DRG N°
8D515J97PA-C
NPRDS / PROJECT
859
This document is the property of
SOURIAU
it must not be reproduced or
communicated without permission
SHEET
1/2
Contact Layout
Country
FR
Not Listed
PN: 8D515J97PA
A
ISS
DATE
Designed By:
TITLE
SCALE
NA
SOURIAU
FORMAT
A3
MOD N°
CUSTOMER DRAWING
Date:
General linear
Tolerances:
WWW.SOURIAU.COM
SOURIAU DRG N°
8D515J97PA-C
NPRDS / PROJECT
859
SOURIAU
SHEET
2/2
很抱歉,暂时无法提供与“8D515J97PA”相匹配的价格&库存,您可以联系我们找货
