8D517J08BN
8D517J08BN
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8 针位圆形连接器 插头外壳 自由悬挂 耦合螺母
8D517J08BN 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal ØS 35.7 Max Z' 31.5 Max VV THREAD M25x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Composite -Shell Plating : Olive drab Cadmium -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D517J08BN -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +175°C : 2000 hours -Mass : 33.6 g ± 10% A 14-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D 5 - 17 J 08 B SCALE N NA SHELL TYPE : Plug with RFI Shielding CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 17 PLATING : J = Jurisdiction & Control List Not Listed ORIENTATION : N SOURIAU Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : SOCKET(500 Matings) Olive drab Cadmium CONTACT LAYOUT : 17-08 FORMAT A3 SOURIAU DRG N° 8D517J08BN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D517J08BN A 14-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D517J08BN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D517J08BN
物料型号:8D517J08BN
器件简介: - 该器件为SOURIAU品牌的Composite Plug 8D系列的插头,设计用于连接。 - 包含射频干扰(RFI)屏蔽的插头外壳和标准压接接触件。
引脚分配: - 接触件布局格式为17-08,表示该型号具有17个引脚,其中8个用于信号传输。
参数特性: - 质量:33.6克,公差为±10% - 温度范围:-65°C至+175°C - 耐盐雾测试:2000小时 - 耐久性:500次配对周期
功能详解: - 提供了射频干扰屏蔽以减少电磁干扰。 - 采用标准压接接触件,确保良好的电信号传输。 - 通过严格的环境测试,确保在极端条件下的可靠性。
应用信息: - 适用于需要高可靠性和电磁兼容性的军事、航空和工业应用。
封装信息: - 外壳类型:带有射频干扰屏蔽的插头 - 接触类型:标准压接接触件和插座(500次配对) - 外壳材料:复合材料 - 外壳镀层:铜合金 - 接触镀层:金层,厚度至少0.8微米
8D517J08BN 价格&库存
很抱歉,暂时无法提供与“8D517J08BN”相匹配的价格&库存,您可以联系我们找货
8D517J08BN
库存:326
