8D517M20PN-LC
8D517M20PN-LC
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    20 针位圆形连接器 插头外壳 自由悬挂 耦合螺母
8D517M20PN-LC 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal ØS 35.7 Max Z' 31.5 Max VV THREAD M25x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Composite -Shell Plating : Nickel -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D517M20PNL -Delivered without Souriau contacts -Temperature Range -Salt Spray : -65°C to +200°C : 2000 hours A 17-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D SHELL TYPE : Plug with RFI Shielding CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 17 PLATING : M = Jurisdiction & Control List Not Listed 5 - 17 M 20 P N SCALE L Delivered W/O Contacts ORIENTATION : N NA SOURIAU Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : PIN(500 Matings) Nickel CONTACT LAYOUT : 17-20 FORMAT A3 SOURIAU DRG N° 8D517M20PNL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D517M20PNL A 17-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D517M20PNL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D517M20PN-LC
- 物料型号: 8D517M20PNL - 器件简介: 该连接器基于MIL-DTL-38999系列III标准,具有金层覆盖铜合金的接触镀层,最小厚度为0.8微米。密封和垫圈由硅橡胶制成,外壳材料为复合材料,绝缘体为热塑性材料,镍制。 - 引脚分配: 17个标准压接接触,布局为17-20A3,接触类型为PIN,可承受500次配对循环。 - 参数特性: 工作温度范围为-65°C至+200°C,耐盐雾时间可达2000小时。耐用性为500次配对循环。 - 功能详解: 该连接器设计用于满足军事和航空航天应用的严苛环境要求,具有RFI屏蔽的插头。 - 应用信息: 适用于需要高可靠性和环境耐受性的场合,如军事和航空航天领域。 - 封装信息: 该连接器为插头类型,带有RFI屏蔽,接触布局为17-20A3,接触类型为PIN。
8D517M20PN-LC 价格&库存
很抱歉,暂时无法提供与“8D517M20PN-LC”相匹配的价格&库存,您可以联系我们找货
