8D519J32BA
8D519J32BA
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    32 针位圆形连接器 插头外壳 自由悬挂 耦合螺母
8D519J32BA 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal ØS 38.5 Max Z' 31.5 Max VV THREAD M28x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Composite -Shell Plating : Olive drab Cadmium -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D519J32BA -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +175°C : 2000 hours -Mass : 44.7 g ± 10% A 18-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D 5 - 19 J 32 B SCALE A NA SHELL TYPE : Plug with RFI Shielding CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 19 PLATING : J = Jurisdiction & Control List Not Listed ORIENTATION : A SOURIAU Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : SOCKET(500 Matings) Olive drab Cadmium CONTACT LAYOUT : 19-32 FORMAT A3 SOURIAU DRG N° 8D519J32BA-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D519J32BA A 18-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D519J32BA-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D519J32BA
1. 物料型号:8D519J32BA 2. 器件简介: - 标准:基于MIL-DTL-38999系列III - 壳体材料:复合材料 - 壳体镀层:橄榄色镉 - 接触件:铜合金 - 绝缘体:热塑性材料 - 密封件和橡胶垫:硅橡胶 - 国家管辖和控制清单:未列出 - 接触件镀层:铜合金上的金镀层,最小0.8微米 - 耐久性:500次配对循环 - 重量:44.7克±10% - 温度范围:-65°C至+175°C - 盐雾测试:2000小时 3. 引脚分配:19-32SOURIAU DRG N° A3 4. 参数特性: - 螺纹规格:M28x1-6g - 壳体尺寸:19 - 一般线性公差:NPRDS / PROJECT 859 5. 功能详解: - 该连接器为标准压接接触件 - 壳体类型:带有RFI屏蔽的插头 - 接触类型:标准压接接触件和插座(500次配对) 6. 应用信息: - 适用于需要高耐久性和宽温度范围的应用 - 适用于需要RFI屏蔽的应用 7. 封装信息: - 格式:8D519J32BA-C
8D519J32BA 价格&库存
很抱歉,暂时无法提供与“8D519J32BA”相匹配的价格&库存,您可以联系我们找货
