8D523J35SB-LC
8D523J35SB-LC
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    100 针位圆形连接器 插头外壳 自由悬挂 耦合螺母
8D523J35SB-LC 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal ØS 44.9 Max Z' 31.5 Max VV THREAD M34x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Composite -Shell Plating : Olive drab Cadmium -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D523J35SBL -Delivered without Souriau contacts -Temperature Range -Salt Spray : -65°C to +175°C : 2000 hours -Mass : 42.5 g ± 10% A 06-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D SHELL TYPE : Plug with RFI Shielding CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 23 PLATING : J = Jurisdiction & Control List Not Listed 5 - 23 J 35 S B SCALE L Delivered W/O Contacts ORIENTATION : B NA SOURIAU Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : SOCKET(500 Matings) Olive drab Cadmium CONTACT LAYOUT : 23-35 FORMAT A3 SOURIAU DRG N° 8D523J35SBL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D523J35SBL A 06-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D523J35SBL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D523J35SB-LC
物料型号:8D523J35SBL
器件简介: - 这是一个符合MIL-DTL-38999系列III标准的连接器。 - 插头带有射频干扰屏蔽(RFI Shielding)。 - 材料包括铜合金接触件镀金0.8微米,硅橡胶密封件,复合材料外壳。
引脚分配: - 接触件布局遵循SOURIAU的23-35标准。
参数特性: - 温度范围:-65°C 至 +175°C。 - 盐雾测试:2000小时。 - 耐久性:500次插拔循环。 - 质量:42.5克,允许误差±10%。
功能详解: - 该连接器设计用于严苛环境,如军事和航空航天领域。 - 提供射频干扰屏蔽以减少电磁干扰。
应用信息: - 适用于需要高可靠性和环境耐受性的场合。
封装信息: - 尺寸和公差遵循NPRDS/PROJECT 859标准。 - 插头类型为带有射频干扰屏蔽的标准压接接触件。 - 外壳材料为复合材料,颜色为橄榄色,也提供镉镀铜合金版本。
其他信息: - SOURIAU公司保留对任何不符合双方或第三方(专业推荐、技术通知)发布的规格使用产品引起的不符合性或损害的责任。 - 文档由SOURIAU设计,归SOURIAU所有,未经许可不得复制或传播。
8D523J35SB-LC 价格&库存
很抱歉,暂时无法提供与“8D523J35SB-LC”相匹配的价格&库存,您可以联系我们找货
