8D523J53PB-LC
8D523J53PB-LC
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D 53C 53#20 PIN PLUG
8D523J53PB-LC 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal ØS 44.9 Max Z' 31.5 Max VV THREAD M34x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Composite -Shell Plating : Olive drab Cadmium -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D523J53PBL -Delivered without Souriau contacts -Temperature Range -Salt Spray : -65°C to +175°C : 2000 hours -Mass : 34.1 g ± 10% A 06-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D SHELL TYPE : Plug with RFI Shielding CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 23 PLATING : J = Jurisdiction & Control List Not Listed 5 - 23 J 53 P B SCALE L Delivered W/O Contacts ORIENTATION : B NA SOURIAU Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : PIN(500 Matings) Olive drab Cadmium CONTACT LAYOUT : 23-53 FORMAT A3 SOURIAU DRG N° 8D523J53PBL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D523J53PBL A 06-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D523J53PBL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D523J53PB-LC
物料型号:8D523J53PBL 器件简介:该器件为SOURIAU公司生产的8D系列的Composite Plug,具有RFI屏蔽功能的插头。
引脚分配:引脚布局为23-53,即23个引脚至53个引脚。
参数特性:标准为MIL-DTL-38999 Series III,外壳材料为复合材料,外壳镀层为橄榄色镉。
连接器尺寸为44.9mm最大,31.5mm最大,螺纹为M34x1-6g。
功能详解:该产品适用于-65°C至+175°C的温度范围,2000小时的耐久性,500次配对周期。
接触镀层为铜合金上镀金,最小0.8微米。
绝缘体为硅橡胶,重量为34.1克±10%。
应用信息:适用于需要RFI屏蔽和高耐久性连接的应用场景。
封装信息:封装类型为插头,带有RFI屏蔽,接触类型为标准压接接触,外壳尺寸为23。
8D523J53PB-LC 价格&库存
很抱歉,暂时无法提供与“8D523J53PB-LC”相匹配的价格&库存,您可以联系我们找货
