8D523M06BN
8D523M06BN
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D 6C 6#8 SKT PLUG
8D523M06BN 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal ØS 44.9 Max Z' 31.5 Max VV THREAD M34x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Composite -Shell Plating : Nickel -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D523M06BN -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +200°C : 2000 hours A 06-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D 5 - 23 M 06 B SCALE N NA SHELL TYPE : Plug with RFI Shielding CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 23 PLATING : M = Jurisdiction & Control List Not Listed ORIENTATION : N SOURIAU Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : SOCKET(500 Matings) Nickel CONTACT LAYOUT : 23-06 FORMAT A3 SOURIAU DRG N° 8D523M06BN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D523M06BN A 06-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D523M06BN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D523M06BN
物料型号:TCA6424A, 一种I2C总线控制的I/O扩展器,用于增强微控制器的I/O功能。
器件简介:TCA6424A是一个高度集成的I/O扩展器,支持I2C通信协议,适用于需要扩展GPIO的应用。
引脚分配:TCA6424A有24个可编程的GPIO引脚,分为4个端口,每个端口6个引脚。
参数特性:工作电压范围2.0V至5.5V,I2C地址可编程,支持400kHz和1MHz的I2C总线速率。
功能详解:TCA6424A具有输入/输出模式配置、中断功能、上拉/下拉电阻配置等功能。
应用信息:适用于工业控制、智能家居、医疗设备等领域,需要扩展I/O接口的场景。
封装信息:提供多种封装选项,如QFN、SOIC等。
8D523M06BN 价格&库存
很抱歉,暂时无法提供与“8D523M06BN”相匹配的价格&库存,您可以联系我们找货
