8D523M35SB
8D523M35SB
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    100 针位圆形连接器 插头,母插口 压接
8D523M35SB 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal ØS 44.9 Max Z' 31.5 Max VV THREAD M34x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Composite -Shell Plating : Nickel -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D523M35SB -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +200°C : 2000 hours -Mass : 67.5 g ± 10% A 07-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D 5 - 23 M 35 S SCALE B NA SHELL TYPE : Plug with RFI Shielding CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 23 PLATING : M = Jurisdiction & Control List Not Listed ORIENTATION : B SOURIAU Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : SOCKET(500 Matings) Nickel CONTACT LAYOUT : 23-35 FORMAT A3 SOURIAU DRG N° 8D523M35SB-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D523M35SB A 07-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D523M35SB-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D523M35SB 价格&库存
很抱歉,暂时无法提供与“8D523M35SB”相匹配的价格&库存,您可以联系我们找货
