8D523W35SE-LC
8D523W35SE-LC
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    100 针位圆形连接器 插头外壳 自由悬挂 耦合螺母
8D523W35SE-LC 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal ØS 44.9 Max Z 31 Max VV THREAD M34x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Aluminium -Shell Plating : Olive drab Cadmium -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D523W35SEL -Delivered without Souriau contacts -Temperature Range -Salt Spray : -65°C to +175°C : 500 hours -Mass : 50 g ± 10% A 07-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D SHELL TYPE : Plug with RFI Shielding CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 23 PLATING : W = Jurisdiction & Control List Not Listed 5 - 23 W 35 S E SCALE L Delivered W/O Contacts ORIENTATION : E NA SOURIAU Latest modification - by MOD N° CUSTOMER DRAWING Date: Aluminium Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : SOCKET(500 Matings) Olive drab Cadmium CONTACT LAYOUT : 23-35 FORMAT A3 SOURIAU DRG N° 8D523W35SEL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D523W35SEL A 07-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Aluminium Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D523W35SEL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D523W35SE-LC
- 物料型号: 8D523W35SEL-C - 器件简介: 该连接器为铝制插头,具有射频干扰屏蔽(RFI Shielding),适用于23至35个接触点的布局。 - 引脚分配: 提供了两种接触类型:标准压接接触点和插座(500次配对) - 参数特性: - 质量:50g ± 10% - 绝缘体:热塑性橄榄绿 - 接触材料:铜合金 - 交付时不包含Souriau接触点 - 温度范围:-65°C 至 +175°C - 盐雾测试:500小时 - 配对周期:500次 - 耐用性:接触电镀至少0.8µm的金层 - 标准:基于MIL-DTL-38999系列III - 硅橡胶密封圈和铝制垫圈 - 壳体材料和电镀 - 功能详解: 文档未提供详细功能描述,但可以推断该连接器设计用于需要射频屏蔽的严苛环境。 - 应用信息: 适用于需要高耐用性和环境抗性的应用。 - 封装信息: 提供了连接器的尺寸信息,例如最大尺寸和螺纹规格(M34x1-6g)。
8D523W35SE-LC 价格&库存
很抱歉,暂时无法提供与“8D523W35SE-LC”相匹配的价格&库存,您可以联系我们找货
