8D525J24PC-LC
8D525J24PC-LC
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D 24C 12#16 12#12 PIN PLUG
8D525J24PC-LC 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal ØS 48 Max Z' 31.5 Max VV THREAD M37x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Composite -Shell Plating : Olive drab Cadmium -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D525J24PCL -Delivered without Souriau contacts -Temperature Range -Salt Spray : -65°C to +175°C : 2000 hours -Mass : 39.6 g ± 10% A 07-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D SHELL TYPE : Plug with RFI Shielding CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 25 PLATING : J = Jurisdiction & Control List Not Listed 5 - 25 J 24 P C SCALE L Delivered W/O Contacts ORIENTATION : C NA SOURIAU Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : PIN(500 Matings) Olive drab Cadmium CONTACT LAYOUT : 25-24 FORMAT A3 SOURIAU DRG N° 8D525J24PCL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D525J24PCL A 07-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D525J24PCL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D525J24PC-LC
1. 物料型号:8D525J24PCL-C 2. 器件简介: - 标准:基于MIL-DTL-38999系列III - 壳体材料:复合材料 - 壳体镀层:橄榄色镉 - 接触件:铜合金 - 绝缘体:热塑性材料 - 密封件和垫圈:硅橡胶 - 国家管辖和控制清单:未列出 3. 引脚分配: - 接触件类型:标准压接接触件 - 壳体尺寸:25 - 接触布局:25-24 4. 参数特性: - 接触镀层:铜合金上镀金,最小0.8微米 - 耐久性:500次配对循环 - 温度范围:-65°C至+175°C - 盐雾测试:2000小时 - 质量:39.6克±10% 5. 功能详解: - 该连接器为一般线性公差 - 该文档是SOURIAU的财产,未经许可不得复制或传播 6. 应用信息: - 该连接器设计用于符合特定规格的产品使用 - SOURIAU不对不符合规格的产品使用导致的任何不符合性或损害负责 7. 封装信息: - 壳体类型:带RFI屏蔽的插头 - 格式:8D525J24PCL-C
8D525J24PC-LC 价格&库存
很抱歉,暂时无法提供与“8D525J24PC-LC”相匹配的价格&库存,您可以联系我们找货
