8D525W11PB
8D525W11PB
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    11 针位圆形连接器 插头,公引脚 压接
8D525W11PB 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal ØS 48 Max Z 31 Max VV THREAD M37x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Aluminium -Shell Plating : Olive drab Cadmium -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D525W11PB -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +175°C : 500 hours A -Mass : 54.48 g ± 10% ISS 09-10-2016 First Release DATE Designed By: TITLE BASIC SERIES: 8D 5 - 25 W 11 P SCALE B NA SHELL TYPE : Plug with RFI Shielding CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 25 PLATING : W = Jurisdiction & Control List Not Listed ORIENTATION : B SOURIAU Latest modification - by MOD N° CUSTOMER DRAWING Date: Aluminium Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : PIN(500 Matings) Olive drab Cadmium CONTACT LAYOUT : 25-11 FORMAT A3 SOURIAU DRG N° 8D525W11PB-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D525W11PB A 09-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Aluminium Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D525W11PB-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D525W11PB
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一种红外发射二极管,用于红外线发射和接收模块。
3. 引脚分配:EL817有两个引脚,分别为阳极和阴极。
4. 参数特性:EL817的参数包括波长940nm,功率2mW,工作电压1.4V,工作电流20mA。
5. 功能详解:EL817用于发射红外光,常用于遥控器、红外通信等领域。
6. 应用信息:EL817可应用于红外线发射和接收模块,实现无线通信功能。
7. 封装信息:EL817采用黑色塑料封装,尺寸为5.7mm x 2.8mm。
8D525W11PB 价格&库存
很抱歉,暂时无法提供与“8D525W11PB”相匹配的价格&库存,您可以联系我们找货
