8D525W37PB-LC
8D525W37PB-LC
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    37 针位圆形连接器 插头外壳 自由悬挂 耦合螺母
8D525W37PB-LC 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal ØS 48 Max Z 31 Max VV THREAD M37x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Aluminium -Shell Plating : Olive drab Cadmium -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D525W37PBL -Delivered without Souriau contacts -Temperature Range -Salt Spray : -65°C to +175°C : 500 hours A -Mass : 46.1 g ± 10% ISS 10-10-2016 First Release DATE Designed By: TITLE BASIC SERIES: 8D SHELL TYPE : Plug with RFI Shielding CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 25 PLATING : W = Jurisdiction & Control List Not Listed 5 - 25 W 37 P B SCALE L Delivered W/O Contacts ORIENTATION : B NA SOURIAU Latest modification - by MOD N° CUSTOMER DRAWING Date: Aluminium Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : PIN(500 Matings) Olive drab Cadmium CONTACT LAYOUT : 25-37 FORMAT A3 SOURIAU DRG N° 8D525W37PBL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D525W37PBL A 10-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Aluminium Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D525W37PBL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D525W37PB-LC 价格&库存
很抱歉,暂时无法提供与“8D525W37PB-LC”相匹配的价格&库存,您可以联系我们找货
