8D709K98AN
8D709K98AN
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    3 针位圆形连接器 插座外壳 面板安装 防火墙使用
8D709K98AN 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal A 30.2±0.3 B 16.53+0.1/-0.15 R 32.5Max S 27±0.4 W 2.2+0.9/-0.1 VV THREAD M12x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Stainless Steel -Shell Plating : Passivated -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D709K98AN -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +200°C : 500 hours A 03-11-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D 7 - 09 K 98 A SCALE N NA SHELL TYPE : Jam nut Receptacle CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 09 PLATING : K = Jurisdiction & Control List Not Listed ORIENTATION : N SOURIAU Latest modification - by Stainless Steel Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : PIN(500 Matings) Passivated CONTACT LAYOUT : 09-98 FORMAT A3 MOD N° CUSTOMER DRAWING Date: SOURIAU DRG N° 8D709K98AN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout Panel cutout Dim B ØC Nominal 16.7±0.1 17.6+0.25/-0 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D709K98AN A 03-11-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Stainless Steel Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D709K98AN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D709K98AN 价格&库存
很抱歉,暂时无法提供与“8D709K98AN”相匹配的价格&库存,您可以联系我们找货
