8D709W98AA
8D709W98AA
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    3 针位圆形连接器 插座外壳 面板安装
8D709W98AA 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal A 30.2±0.3 B 16.53+0.1/-0.15 R 32.5Max S 27±0.4 W 2.2+0.9/-0.1 VV THREAD M12x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Aluminium -Shell Plating : Olive drab Cadmium -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D709W98AA -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +175°C : 500 hours -Mass : 13.91 g ± 10% A 03-11-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D 7 - 09 W 98 A SCALE A NA SHELL TYPE : Jam nut Receptacle CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 09 PLATING : W = Jurisdiction & Control List Not Listed ORIENTATION : A SOURIAU Latest modification - by Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : PIN(500 Matings) Olive drab Cadmium CONTACT LAYOUT : 09-98 FORMAT A3 MOD N° CUSTOMER DRAWING Date: SOURIAU DRG N° 8D709W98AA-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout Panel cutout Dim B ØC Nominal 16.7±0.1 17.6+0.25/-0 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D709W98AA A 03-11-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D709W98AA-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D709W98AA
- 物料型号: 8D709W98AA - 器件简介: 这是一种SOURIAU品牌的铝制插座,属于8D系列,设计用于极端温度范围内使用,从-65°C到+175°C。 - 引脚分配: 文档提供了9个引脚的布局图,但没有提供具体的引脚功能描述。 - 参数特性: - 接触镀层:铜上镀金,最小0.8微米 - 标准:基于MIL-DTL-38999系列III - 密封和垫圈:硅橡胶 - 壳体材料:铝 - 壳体镀层:橄榄色镉 - 绝缘体:热塑性材料 - 接触:铜合金 - 质量:13.91克±10% - 盐雾测试:500小时 - 耐久性:500次配对循环 - 功能详解: 文档没有提供详细的功能解释,但提到了连接器的尺寸和公差。 - 应用信息: 文档没有提供具体的应用信息,但根据其参数特性,该连接器适用于需要在极端温度和恶劣环境下工作的场合。 - 封装信息: 提供了连接器的尺寸和螺纹规格(M12x1-6g),以及面板切口的尺寸。
8D709W98AA 价格&库存
很抱歉,暂时无法提供与“8D709W98AA”相匹配的价格&库存,您可以联系我们找货
8D709W98AA
库存:1
