8D711F35PB-LC
8D711F35PB-LC
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D 13C 13#22D PIN J/N
8D711F35PB-LC 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal A 34.9±0.3 B 19.07+0.1/-0.15 R 32.5Max S 31.8±0.4 W 2.2+0.9/-0.1 VV THREAD M15x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Aluminium -Shell Plating : Nickel -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D711F35PBL -Delivered without Souriau contacts -Temperature Range -Salt Spray : -65°C to +200°C : 48 hours A -Mass : 17.01 g ± 10% ISS 30-09-2016 First Release DATE Designed By: TITLE BASIC SERIES: 8D SHELL TYPE : Jam nut Receptacle CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 11 PLATING : F = Jurisdiction & Control List Not Listed 7 - 11 F 35 P B SCALE L Delivered W/O Contacts ORIENTATION : B NA SOURIAU Latest modification - by CUSTOMER DRAWING Date: Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : PIN(500 Matings) Nickel CONTACT LAYOUT : 11-35 FORMAT A3 MOD N° SOURIAU DRG N° 8D711F35PBL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout Panel cutout Dim B ØC Nominal 19.59+0/-0.25 20.96+0.25/-0 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D711F35PBL A 30-09-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D711F35PBL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D711F35PB-LC 价格&库存
很抱歉,暂时无法提供与“8D711F35PB-LC”相匹配的价格&库存,您可以联系我们找货
