8D711F98BB
8D711F98BB
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D 6C 6#20 SKT J/N
8D711F98BB 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal A 34.9±0.3 B 19.07+0.1/-0.15 R 32.5Max S 31.8±0.4 W 2.2+0.9/-0.1 VV THREAD M15x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Aluminium -Shell Plating : Nickel -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D711F98BB -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +200°C : 48 hours A -Mass : 20.65 g ± 10% ISS 30-09-2016 First Release DATE Designed By: TITLE BASIC SERIES: 8D 7 - 11 F 98 B SCALE B NA SHELL TYPE : Jam nut Receptacle CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 11 PLATING : F = Jurisdiction & Control List Not Listed ORIENTATION : B SOURIAU Latest modification - by CUSTOMER DRAWING Date: Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : SOCKET(500 Matings) Nickel CONTACT LAYOUT : 11-98 FORMAT A3 MOD N° SOURIAU DRG N° 8D711F98BB-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout Panel cutout Dim B ØC Nominal 19.59+0/-0.25 20.96+0.25/-0 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D711F98BB A 30-09-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D711F98BB-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D711F98BB
物料型号为8D711F98BB,属于SOURIAU品牌。
这是一款Jam nut Receptacle,具有标准压接接触件,尺寸为11。
该连接器交付时附带Souriau接触件和配件,耐用性为500次配对循环,热塑性材料,接触镀金,最小0.8微米。
引脚分配方面,该连接器具有11-98的接触布局,首次发布日期为2016年9月30日。
参数特性包括: - 质量:20.65克,公差±10% - 温度范围:-65°C至+200°C - 盐雾测试:48小时
功能详解涉及连接器的机械和环境特性,包括其耐用性和温度范围。
应用信息包括连接器的尺寸和安装方式,适用于需要高耐用性和宽温度范围的应用。
封装信息指出,连接器由铝制成,外壳材料为铝,表面镀铜合金,接触件为镍。
以上信息基于PDF文档的详细解读。
8D711F98BB 价格&库存
很抱歉,暂时无法提供与“8D711F98BB”相匹配的价格&库存,您可以联系我们找货
