8D711W98AN
8D711W98AN
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    6 针位圆形连接器 插座外壳 面板安装
8D711W98AN 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal A 34.9±0.3 B 19.07+0.1/-0.15 R 32.5Max S 31.8±0.4 W 2.2+0.9/-0.1 VV THREAD M15x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Aluminium -Shell Plating : Olive drab Cadmium -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D711W98AN -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +175°C : 500 hours A -Mass : 17.89 g ± 10% ISS 01-10-2016 First Release DATE Designed By: TITLE BASIC SERIES: 8D 7 - 11 W 98 A SCALE N NA SHELL TYPE : Jam nut Receptacle CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 11 PLATING : W = Jurisdiction & Control List Not Listed ORIENTATION : N SOURIAU Latest modification - by CUSTOMER DRAWING Date: Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : PIN(500 Matings) Olive drab Cadmium CONTACT LAYOUT : 11-98 FORMAT A3 MOD N° SOURIAU DRG N° 8D711W98AN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout Panel cutout Dim B ØC Nominal 19.59+0/-0.25 20.96+0.25/-0 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D711W98AN A 01-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D711W98AN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D711W98AN 价格&库存
很抱歉,暂时无法提供与“8D711W98AN”相匹配的价格&库存,您可以联系我们找货
8D711W98AN
库存:3
