8D713K98SB-LC
8D713K98SB-LC
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D 10C 10#20 SKT J/N
8D713K98SB-LC 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal A 38.1±0.3 B 23.82+0.1/-0.15 R 32.5Max S 34.9±0.4 W 2.2+0.9/-0.1 VV THREAD M18x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Stainless Steel -Shell Plating : Passivated -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D713K98SBL -Delivered without Souriau contacts -Temperature Range -Salt Spray : -65°C to +200°C : 500 hours A 28-09-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D SHELL TYPE : Jam nut Receptacle CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 13 PLATING : K = Jurisdiction & Control List Not Listed 7 - 13 K 98 S B SCALE L Delivered W/O Contacts ORIENTATION : B NA SOURIAU Latest modification - by CUSTOMER DRAWING Date: Stainless Steel Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : SOCKET(500 Matings) Passivated CONTACT LAYOUT : 13-98 FORMAT A3 MOD N° SOURIAU DRG N° 8D713K98SBL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout Panel cutout Dim B ØC Nominal 24.26+0/-0.25 25.65+0.25/-0 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D713K98SBL A 28-09-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Stainless Steel Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D713K98SBL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D713K98SB-LC 价格&库存
很抱歉,暂时无法提供与“8D713K98SB-LC”相匹配的价格&库存,您可以联系我们找货
