8D717W26BA
8D717W26BA
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D 26C 26#20 SKT J/N
8D717W26BA 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal A 44.5±0.3 B 30.15+0.1/-0.15 R 32.5Max S 41.3±0.4 W 2.2+0.9/-0.1 VV THREAD M25x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Aluminium -Shell Plating : Olive drab Cadmium -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D717W26BA -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +175°C : 500 hours A -Mass : 49.36 g ± 10% ISS 01-10-2016 First Release DATE Designed By: TITLE BASIC SERIES: 8D 7 - 17 W 26 B SCALE A NA SHELL TYPE : Jam nut Receptacle CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 17 PLATING : W = Jurisdiction & Control List Not Listed ORIENTATION : A SOURIAU Latest modification - by CUSTOMER DRAWING Date: Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : SOCKET(500 Matings) Olive drab Cadmium CONTACT LAYOUT : 17-26 FORMAT A3 MOD N° SOURIAU DRG N° 8D717W26BA-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout Panel cutout Dim B ØC Nominal 30.73+0/-0.25 32.01+0.25/-0 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D717W26BA A 01-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D717W26BA-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D717W26BA 价格&库存
很抱歉,暂时无法提供与“8D717W26BA”相匹配的价格&库存,您可以联系我们找货
8D717W26BA
库存:27
