8D717W26PA
8D717W26PA
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D 26C 26#20 PIN J/N
8D717W26PA 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal A 44.5±0.3 B 30.15+0.1/-0.15 R 32.5Max S 41.3±0.4 W 2.2+0.9/-0.1 VV THREAD M25x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Aluminium -Shell Plating : Olive drab Cadmium -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D717W26PA -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +175°C : 500 hours A -Mass : 38.57 g ± 10% ISS 01-10-2016 First Release DATE Designed By: TITLE BASIC SERIES: 8D 7 - 17 W 26 P SCALE A NA SHELL TYPE : Jam nut Receptacle CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 17 PLATING : W = Jurisdiction & Control List Not Listed ORIENTATION : A SOURIAU Latest modification - by CUSTOMER DRAWING Date: Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : PIN(500 Matings) Olive drab Cadmium CONTACT LAYOUT : 17-26 FORMAT A3 MOD N° SOURIAU DRG N° 8D717W26PA-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout Panel cutout Dim B ØC Nominal 30.73+0/-0.25 32.01+0.25/-0 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D717W26PA A 01-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D717W26PA-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D717W26PA
物料型号: - 产品型号为"8D717W26PA"。
器件简介: - 该产品基于MIL-DTL-38999系列III标准。 - 壳体材料为铝,表面镀橄榄色镉。 - 绝缘体为热塑性材料。 - 接触件为铜合金,镀金层厚度至少为0.8微米。 - 密封件和橡胶垫圈为硅橡胶。
引脚分配: - 该产品为17-26引脚布局,具体引脚尺寸如下: - B:30.73±0.25mm - OC:32.01±0.25mm
参数特性: - 接触件类型:标准压接接触件。 - 耐久性:500次配对循环。 - 温度范围:-65°C至+175°C。 - 盐雾测试:500小时。 - 质量:38.57克±10%。
功能详解: - 该产品为标准压接接触件,具有500次配对循环的耐久性。 - 具有广泛的温度适用范围,适用于恶劣环境下的使用。 - 产品符合SOURIAU的标准,且有明确的规格说明。
应用信息: - 该产品为SOURIAU品牌的8D系列,适用于需要高耐久性和高可靠性的应用场景。
封装信息: - 产品封装类型:Jam nut Receptacle(螺母式插座)。 - 壳体尺寸:17。
8D717W26PA 价格&库存
很抱歉,暂时无法提供与“8D717W26PA”相匹配的价格&库存,您可以联系我们找货
8D717W26PA
库存:60
