8D719F11PN
8D719F11PN
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    11 针位圆形连接器 插座,公形引脚 压接
8D719F11PN 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal A 49.2±0.3 B 33.32+0.1/-0.15 R 32.5Max S 46±0.4 W 3+0.9/-0.1 VV THREAD M28x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Aluminium -Shell Plating : Nickel -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D719F11PN -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +200°C : 48 hours A -Mass : 44.62 g ± 10% ISS 30-09-2016 First Release DATE Designed By: TITLE BASIC SERIES: 8D 7 - 19 F 11 P SCALE N NA SHELL TYPE : Jam nut Receptacle CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 19 PLATING : F = Jurisdiction & Control List Not Listed ORIENTATION : N SOURIAU Latest modification - by CUSTOMER DRAWING Date: Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : PIN(500 Matings) Nickel CONTACT LAYOUT : 19-11 FORMAT A3 MOD N° SOURIAU DRG N° 8D719F11PN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout Panel cutout Dim B ØC Nominal 33.91+0/-0.25 35.18+0.25/-0 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D719F11PN A 30-09-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D719F11PN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D719F11PN 价格&库存
很抱歉,暂时无法提供与“8D719F11PN”相匹配的价格&库存,您可以联系我们找货
