8D721W72SA-LC
8D721W72SA-LC
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D 8C 6#16 2#8 SKT J/N
8D721W72SA-LC 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal A 52.4±0.3 B 36.5+0.1/-0.15 R 32.5Max S 49.2±0.4 W 3+0.9/-0.1 VV THREAD M31x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Aluminium -Shell Plating : Olive drab Cadmium -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D721W72SAL -Delivered without Souriau contacts -Temperature Range -Salt Spray : -65°C to +175°C : 500 hours A 08-11-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D SHELL TYPE : Jam nut Receptacle CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 21 PLATING : W = Jurisdiction & Control List Not Listed 7 - 21 W 72 S A SCALE L Delivered W/O Contacts ORIENTATION : A NA SOURIAU Latest modification - by Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : SOCKET(500 Matings) Olive drab Cadmium CONTACT LAYOUT : 21-72 FORMAT A3 MOD N° CUSTOMER DRAWING Date: SOURIAU DRG N° 8D721W72SAL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout Panel cutout Max. thickness panel for receptacle:Type 7: 3.2 mm Dim B ØC Nominal 37.08+0/-0.25 38.35+0.25/-0 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D721W72SAL A 08-11-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D721W72SAL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D721W72SA-LC 价格&库存
很抱歉,暂时无法提供与“8D721W72SA-LC”相匹配的价格&库存,您可以联系我们找货
